10 years, 7 months ago.
generates an operating stop (NUCLEO F411RE and ENC28J60)
The material used is a map NUCLEO F411RE & ENC28J60.
the source code must be an error that generates an operating stop (less than one hour of operation) installation (buffer overflow, pointer problem ...) I did not find the cause, if someone had an idea ... thank you in advance
but also : https://developer.mbed.org/users/Fo170/code/Nucleo_Web_ENC28J60/
Inspect the code, check all pointer handling operations, You could print debug output to find where the program stops.
printf("$HCHDM,%d,M\r\n", (int)heading);
Printf prints to usb port and in Debian you can use CuteCom to monitor serial ports.
