11 years, 3 months ago.
Problem with mbed NXP LPC1768 digital outputs
My mbed NXP LPC1768 seems to be broken, all pinss are reading 2.22V and when i try and set an output to 0V it still reads 2.22V.
Has anyone else had this problem and how did you solve it?
Can you flash one of the LEDs? If yes, you are probably measuring wrong. If no then you are probably coding wrong ;)
Did you try the HelloWorld example? It looks like your pio is set at an input with PullUp. Just a couple of changes to the HelloWorld code will produce the code below. Connect your multimeter or an LED and resistor to p20.
DigitalOut myled(p20);
        myled = 1;
        wait(1);
        myled = 0;
        wait(1);
I tried the code but still reading 2.22V. The led's on the mbed don't work either. I think some components have failed.
posted by Anth Hunter 09 Dec 2014
