10 years, 8 months ago.
LPC824 WatchDog
Team Is this how I activate watchdog? <code> void kick(float s) {
uint32_t clk = SystemCoreClock / 16; WD has a fixed /4 prescaler, PCLK default is /4
LPC_WWDT->TC = s * (float)clk;
LPC_WWDT->MOD = 0x3; Enabled and Reset
feedtg();
void feedtg() {
LPC_WWDT->FEED = 0xAA;
LPC_WWDT->FEED = 0x55;
</code>
At the begingin I call kick the I frequently call feedtg().... right?
First, you can use <<code>> tag to put your code in the questions.
About WDT usage, please refer example code here: https://developer.mbed.org/users/MACRUM/code/Watchdog-test-lpc824/
You have to enable clock and power domain in the WWDT. I hope this helps.
