11 years, 4 months ago.
Solved: Programs with SPI connection to RPi won't start
Hi, relative MCU-newbie here ...
I have a Raspberry Pi connected to a NXP LPC812-max via SPI. I got it working ... with some slight of hand.
Set-up: the 4 SPI + GND connections between the RPi and the LPC812 are in place (directly connected). The RPi runs the following SPI-master code:
Code for RPi SPI master
import spidev
import time
spi = spidev.SpiDev()
spi.open(0,0)
try:
while True:
for i in range(256):
send = [i]
print "RPi SPI sending:", send
resp = spi.xfer2(send)
print "RPi received:", resp[0]
time.sleep(1)
except KeyboardInterrupt:
spi.close()
The LPC812 runs the following SPI-slave code:
Code for LPC812-max SPI slave
{ Serial serial(USBTX, USBRX); // open serial communication
serial.printf("Mbed getting ready");
SPISlave device(P0_14, P0_15, P0_12, P0_13); // mosi, miso, sclk, css
device.format(8,0); // bits=8, mode=0
device.reply(0x21); // Prime SPI with first reply
if(device.receive()) {
int v = device.read(); // Read byte from master
v = v & 0xFF; // Only take the lower 8 bits
serial.printf("Mbed has received: %d\r\n",v);
v = (v + 1) % 0x100; // Add one to it, modulo 256
serial.printf("Mbed is going to send: %d\r\n",v);
device.reply(v); // Make this the next reply
If I start the RPi code and do a reset on the LPC812 nothing happens. I have to disconnect the SCK, do a reset and re-insert the SCK before everything runs as it should. Also if I load another program such as a blinking led, it won't start until I disconnect, reset and re-connect the SCK.
What am I doing wrong?
Wim Huiskamp provided the answer: the LPC812 version C4 (which is indeed on the LPC812-max board I use) has the ISP entry pin on PI00_12 (P0_12), which is also used for the SPI SCK. The SPI SCK in mode 0 will (almost always) cause the board to expect a program to be flashed after a reset. So, I changed the SPI mode to 2 (inverted SCK) and now my program starts (almost always).
posted by Jeroen Voogd 09 Dec 2014Note that this problem will bite you whenever you use P0_12 as DigitalIn (or even DigitalOut) pin that could be at a Low level during a hard reset or power-on reset! The LPC812 will then enter the ISP bootmode and expects to be flashed using the serial port rather than start normally.
posted by Wim Huiskamp 14 Dec 2014
