10 years, 4 months ago.
External Xtal in lpc824
Team 1) Do I need to make any changes in firmware to use an external crystal? 2) Also my cricuit is built fo external crystal but i dont solder anything it and am using the internal oscillator. will soldering an external crystal use the external one
Thanks in advance
Surendar S
You need to make some changes to the clock selection startup and PLL code to use an external xtal. Check the mbed source code.
