10 years, 8 months ago.
QoS 2 not responded
Hi Team,
I am trying HelloMQTT on FRDM-K64F board, commenting out LCD lines. It works fine for QoS 0 and 1, but the client is stopping at receiving QoS 2.
Thank you for your help.
Kojo
10 years, 6 months ago.
hi,
I am receiving junk characters or some previous data appended to my currently subscribed message. I have enabled clean session and not enabled any retention. Your suggestions will be very useful.
Regards, Sriram
I've updated HelloMQTT now, so it should work for you. A change in the underlying library meant that QoS 2 processing was switched off, unless
- define MQTTCLIENT_QOS2 1
was used.
I also made it easy to not use the LCD screen by setting #define USE_LCD 0.
Hi Ian,
Thank you for your prompt response.
It worked!
Just one thing, I see received message of QoS 2 with "qos 1", not sure if this is as expected.
Message arrived: qos 1, retained 0, dup 0, packetid 2 Payload Hello World! QoS 2 message from app version 0.500000
Even minor was that some lcd.cls() got error when USE_LCD is 0. I suppose we can eliminate them.
Kojo
