11 years, 4 months ago.
Serial port RX problem
I am using ST Nucleo F103RB platfrom with IAR compiler 7.20 printf to serial port is OK. But, if I want to read from serial port this is not possible. I am using Serial_HelloWorld_Mbed example and function is blocked on getc
There is no problem with ARM or GCC compiler. Only with IAR...
Best regards Milan
I can't find a reason why it would fail only in IAR, probably retarget problem?
To be able to track this, yhou can create an issue on mbed SDK github repository, https://github.com/mbedmicro/mbed/issues. As this is related to the SDK, not online IDE.
0xc0170
