10 years, 7 months ago.
After upgrading to buid 221 the COM disappear
I have updated a the FRDM K22F firmware from v.0203 to v.0221.
The operation completed correctly, but now I do not see the COM port.
If I change the USB port, I see the "Virtual Com Port", but connecting the USB cable to the SDA-USB port (near the Reset button) does not show any COM port connected, only the MSD drive "MBED".
I tryed to reboot the PC but nothing changed. If I reload the v.0203 the serial port is correctly shown, but if I reload again the v.0221... no COM port!
Thanks for any help Franco
If it is under the Windows OS, try to reinstall mbed Windows serial port driver (after you update the firmware of your board): https://developer.mbed.org/media/downloads/drivers/mbedWinSerial_16466.exe
After that, when you plug your mbed board, it should show "Installing new hardware..... OK" and it should work.
Addition - Read the entire page for winserial driver: https://developer.mbed.org/handbook/Windows-serial-configuration
Regards, Miloje
