10 years, 8 months ago.
How to use set_option().... Must I diggging lwip source code ???
HOW TO FEED [SOF_REUSEADDR] TO set_option() ???? I must proceed into code jungle with using set_option() because there is no documents.... NO ! I cant patient that, So I modified source code of lib. directly..... in sockets.c, tcp_bind(), around #if SO_REUSE block , comment outed 'Check if the address already is in use' then it's Ok, my mission is completed. btw, How they using this lib. without document ?
