10 years, 8 months ago.
Modserial & interrupts
Hi everyone, I need help with interrupts while using modserial.
The problem I am having is it appears NVIC_DisableIRQ(UART1_IRQn); && NVIC_EnableIRQ(UART1_IRQn); are not disabling/enabling the interrupts. I have also tried: disable_interrupt() enable_interrupt()
Specifically when I call the disableIRQ and transmit over serial I am capturing the talk back from my own Tx. This intern is causing another IRQ RX call and I get stuck in a forever loop of the same data transmitted over and over.
interrupt attach
line.attach(&txCallback, MODSERIAL::TxIrq);
line.attach(&rxCallback, MODSERIAL::RxIrq);
line.attach(&txEmpty, MODSERIAL::TxEmpty);
I notice the documentation shows SERIAL instead of MODSERIAL in the attach. I am wondering if this is the cause of the IRQ not disabling.
I also tried uart1-3 with no luck based on this post: https://developer.mbed.org/questions/135/UART-and-pins/
So what do you do when you are transmitting a 5 to 10 bytes and do not want to receive your own transmission? Is there a way to only disable the Rx interrupt? Not sure if this is needed since the line is only half duplex but just a thought.
Rob
Can you post a simple program where it is going wrong? Since it is unlikely those functions are broken.
posted by Erik - 23 Jul 2015Usage would be as follows, disable IRQ - send selected bytes based on requester - re-enable IRQ.
Example usage
void lineRequestData(char requestVal) { switch(requestVal) { case(0x01): { NVIC_DisableIRQ(UART1_IRQn); line.putc(byte0); line.putc(byte1); line.putc(byte2); line.putc(byte3); line.putc(byte4); NVIC_EnableIRQ(UART1_IRQn); break; } case(0x02): { NVIC_DisableIRQ(UART1_IRQn); line.putc(byte0); line.putc(byte1); line.putc(byte2); line.putc(byte3); line.putc(byte4); NVIC_EnableIRQ(UART1_IRQn); break; } } }
