10 years, 9 months ago.
I m not able to understand the source of error...pls help
<<code>>
TextLCD lcd(p19, p20, p21, p22, p23, p24);
DigitalOut switchengine(p5);
DigitalIn pin_up(p14);
DigitalIn pin_down(p15);
InterruptIn pin_start(p16);
void timeloop(int i);
void timeloop(int i){
float T= i;
float timeleft = T;
lcd.cls();
lcd.locate(1,0);
lcd.printf("ENGINE START");
wait(1);
while(timeleft >0){ switchengine=1; if(timeleft<4){ lcd.cls(); lcd.locate(1,0); lcd.printf("Time = %2.2f mn", T*15); wait(0.5); lcd.cls(); } else{ lcd.cls(); lcd.locate(1,0); lcd.printf("Time = %1.2f Hr",(T)*15/60.0); wait(0.5); lcd.cls(); }
lcd.locate(0,1);
lcd.printf("Timeleft:%1.2f H",timeleft*15/60.0);
wait(900);
timeleft;
lcd.cls();
} switchengine=0; lcd.cls(); lcd.locate(2,0); lcd.printf("ENGINE OFF");
int i=0; pin_up.mode(PullDown); pin_down.mode(PullDown); pin_start.mode(PullDown); float time;
lcd.locate(3,0); lcd.printf("SET TIME");
pin_start.rise(&timeloop); Error: No instance of overloaded function "mbed::InterruptIn::rise" matches the argument list in "main.cpp"
<</code>>
Please use the <<code>> and <</code>> tags on separate lines to keep the text readable
void timeloop(int i); // prototype not really needed here if the code follows directly afterwards
float T= i;
float timeleft = T;
lcd.cls();
lcd.locate(1,0);
wait(1);
while(timeleft >0){
switchengine=1;
if(timeleft<4){
lcd.cls();
lcd.locate(1,0);
lcd.cls();
else{
lcd.cls();
lcd.locate(1,0);
wait(0.5);
lcd.cls();
lcd.locate(0,1);
wait(900);
timeleft--;
lcd.cls();
switchengine=0;
lcd.cls();
lcd.locate(2,0);
int i=0;
float time;
lcd.locate(3,0);
pin_start.rise(&timeloop); // Error: No instance of overloaded function "mbed::InterruptIn::rise" matches the
// argument list in "main.cpp"
The problem is caused by the fact that callback functions are not allowed to have parameters.
Remove the ''int i'' parameter in timeloop(int i). Use a global variable if some parameter is needed. Also, the long wait(900) inside a callback function may not be a good idea if you get multiple buttonpresses or add more callbacks from other buttons later on.
how can I use global varialble. I dont have any idea about it. Please explain. I want the loop to restart at previous value of 'i', instead of setting its value again when not required.
posted by 16 Jul 2015I think you want your engine to run for a set number of 15 minute intervals. This can be done with a Timeout object set to 15 minutes (= 900 s). That object will call a function to decrement the interval counter and update the display.
Something like this:
Timeout quarter; //timeout called every 15min when running
int setNrQuarters; //selected number of quarters
float runtime; //currently set runtime interval in quarters
float runtimeleft; //remaining runtime interval in quarters
void runtimeUpdate();
void displayUpdate();
void startRun() ;
//called when 15min has passed
void runtimeUpdate(){
runtimeleft--;
displayUpdate();
//update the display and start/stop the engine
void displayUpdate(){
if (runtimeleft ==0)
// we are done
switchengine=0;
//update display
lcd.cls();
lcd.locate(2,0);
else {
//engine should be running
switchengine=1;
//update display first line
lcd.cls();
lcd.locate(1,0);
if (runtimeleft < 4){
lcd.printf("Time = %2.2f mn", (runtime*15);
else{
lcd.printf("Time = %1.2f Hr", (runtime*15.0)/60.0);
//update display second line
lcd.locate(0,1);
lcd.printf("Timeleft:%1.2f H", (runtimeleft*15.0)/60.0);
// now start timeout to call again in 15min
quarter.attach(&runtimeUpdate, 900);
// init and start the run
void startRun() {
runtime = setNrQuarters;
runtimeleft = runtime;
lcd.cls();
lcd.locate(1,0);
wait(1);
displayUpdate();
int i=0;
float time;
lcd.locate(3,0);
setNrQuarters = 1; //Initial selected number of quarters
pin_start.rise(&startRun); // call to (re)start engine run)
while (1); // just wait for keypress
Assigned to 10 years, 2 months ago.
