11 years, 4 months ago.
F401RE Analog In Oddness part deux
I had an issue trying to read external voltage using a voltage divider to the analog inputs (http://developer.mbed.org/questions/5279/F401RE-Analog-In-oddness/). I've distilled it down further to the basics.
The problem I'm seeing is different results with different analog input lines on a F401RE. A0 is significantly different than A1-A5. I read that this chip has a single ADC, and the various inputs are multiplexed to it. Thus they should all have very similar results.
So one of three things is going on:
- My expectation of how AnalogIn works is wrong, and this kind of diversity between pins is expected.
- Something is wrong with my F401RE (unfortunately I only have one at this time).
- The way the F401RE mbed library is interfacing with the ADC is wrong in some way.
Here are the results of testing A0-A5 with a simple resistor to either Ground or AVdd. The raw values from AnalogIn are multiplied by 100, so the range is 0-100 instead of 0.0 to 1.0. My testing procedure is to display the values of all A0-A6 inputs at once on an LCD display, and then I switch from one input to another using the same resistor / test lead. Every time I test I get the same steady results for each respective input.
100k (98.0k actual) To ground: A0: 12.8 A1: 8.0 A2: 7.6 A3: 7.7 A4: 8.0 A5: 8.1 To AVDD A0: 92.4 A1: 91.4 A2: 89.0 A3: 89.0 A4: 91.5 A5: 91.5 1M (993k actual) To ground: A0: 21.4 A1: 13.4 A2: 12.2 A3: 12.5 A4: 12.9 A5: 13.3 To AVDD A0: 86.6 A1: 85.3 A2: 81.3 A3: 80.9 A4: 85.9 A5: 85.6
The manifestation of this is that I can't read external voltages using a voltage divider accurately at all. Even if I try and calibrate around it, the problem seems to not be linear.
The datasheet lists the maximum impedance used as 50kOhm, and it also gives an equation (which I cannot easily copy) to calculate it depending on the settings. But tbh I would then expect the 100kOhm to still work quite fine. It might also be related to the PCB design, although 10% would be alot.
And tbh they aren't that different, with one or two exceptions, the main difference is that if you tie it to GND/VDD it doesn't return 0/100.
posted by Erik - 29 Nov 2014
