10 years, 8 months ago.
RX, TX
This is clearly a nood question but, when you declare the object: AX12 myax12 (p9, p10, 1);
You declare separate pins for RX and TX while the AX12 has a single pin for both directions of communication. So how do you split that pin? Or does that pin go to both RX and TX pins on the MCU?
Thanks for the help!
