10 years, 7 months ago.
WIZwiki-W7500 SystemCoreClock at 20MHz instead of 48MHz
A quick first test with the new WIZwiki-W7500 platform shows that the clockfrequency is 20MHz, which is less than half the advertised value of 48MHz. Turns out that this is due to the fact that the PLL freq calculation register is not initialised and uses its reset value of 0x050200 instead. That means the PLL config values are: M=5, N=2, OD=1. So the SystemCoreClock = 8MHz * M / N * 1 / OD = 20 MHz
This bug should be fixed in the W7500 mbed source code, probably in system_W7500x.c, for example by adding:
CRG->PLL_FCR = 0x060100;
I also noted that the internal Xtal (8MHz) is used instead of the (mounted) external Xtal (8 MHz). Any reason for that?
The code below provides the current settings:
DigitalOut red(LED_RED); // PC_8
DigitalOut green(LED_GREEN); // PC_9
DigitalOut blue(LED_BLUE); // PC_5
uint8_t M,N,OD;
pc.printf("Hello World from W7500!\n\r");
pc.printf("CPU SystemCoreClock is %d Hz\r\n", SystemCoreClock);
#ifdef SYSCLK_EXTERN_OSC
pc.printf("SYSCLK_EXTERN_OSC = 1; EXTERN_XTAL = %d\n\r", EXTERN_XTAL);
#else
pc.printf("SYSCLK_EXTERN_OSC = 0; INTERN_XTAL = %d\n\r", INTERN_XTAL);
#endif
pc.printf("CRG->PLL_FCR = 0x%0X\n\r", CRG->PLL_FCR);
OD = (1 << (CRG->PLL_FCR & 0x01)) * (1 << ((CRG->PLL_FCR & 0x02) >> 1));
N = (CRG->PLL_FCR >> 8 ) & 0x3F;
M = (CRG->PLL_FCR >> 16) & 0x3F;
pc.printf("M = %d; N = %d; OD = %d\n\r", M, N, OD);
red = 1;
green = 1;
blue = 1;
red = !red;
wait(0.5);
pc.putc('#');
10 years, 1 month ago.
PLease, can you report this to github, and I'll tag reponsible ppl for wiznet port to have a look.
Thanks
Martin, I did raise this on github last year. See https://github.com/mbedmicro/mbed/issues/1237#issuecomment-120842504
Comment by hjjeon0608 was (3 Jul 2015) We set core clock as 20MHz on purpose not bug. Do I change the core clock to maximum frequency(48MHz)??
We mounted external Xtal for user to test. We think it is enough to use internal Xtal. And do I change also???
posted by 03 Feb 201610 years ago.
Also waiting for this to happen
There is a discussion on github, please have a look https://github.com/mbedmicro/mbed/issues/1524
posted by 06 Mar 20169 years, 10 months ago.
Hello, it would be very nice to use 48MHz, because it affects WIZwiki 7500 and 7500P. When will you change this in the library? Would be awesome, thank you.
