10 years, 8 months ago.
Is usb ethernet still being developed ?
Hi
I'd like to connect a 3G radio which supports CDC ECM
Is USBEthernet a good choice?
Do you think I'll have to make changes?
Thanks
John
10 years, 7 months ago.
Hi John,
USBEthernet is not supposed to work with modem, you are perhaps looking for a Host module to support USB Serial, or a host-side support for CDC-ECM, which is not in mbed AFAIK.
USBEthernet is to connect the mbed board (as a guest) to a USB Host and realize a CDC_ECM point-to-point connection, such as https://en.wikipedia.org/wiki/Ethernet_over_USB
Thanks,
I think my use of the word modem was incorrect - I've changed it to radio in my question.
You are correct - I'm looking to use a host platform which has a USB host port .Then connect the radio to the platform USB host port. The radio already supports USB ECM in the same way that USB ECM ethernet hardware works
I am hoping to use the radio with the standard arm mbed IP stack in the same way as USB ECM ethernet hardware - is this possible? -any direction on where to start?
posted by John Thompson 17 Jul 2015
