10 years, 9 months ago.
Difference between shield and mote
Hi, I am testing the SX1272 LoRa by programming the STM32 F072R8. I first used your sx127x_simple_TX_shield programm, changed the frequency to 868MHz as I'm in France; it complied correctly but it didn't run. And then, I used the sx127x_simple_TX_mote programm and it ran ! So, what is the difference between the shield and the mote ? The next step is to test a ping pong program between 2 SX1272, can I continue my project by using the mote ? Looking for your reply. Thank you. Gdogan
10 years, 8 months ago.
The only difference between sx127x_simple_TX_shield and sx127x_simple_TX_mote is the pin assignments and antenna switch function.
