10 years, 9 months ago.
Ping on Arch Max does not work
Ping on Arch Max does not work. On the Arch Pro it works just fine. Both boards have the same Ethernet Transceiver chip, the DP83848J.
While the Arch Max cannot be pinged, it just works fine with the TCP server/client, NTP, etc., as expected.
Is this a bug?
Kind regards, Jack.
Hi, this is due to conflict with hardware checksum generation of STM32. You need to patch lwIP modification from ST.
Modify EthernetInferface/lwip/core/ipv4/icmp.c file like following.
in icmp_input() function
/* adjust the checksum */
if (iecho->chksum >= PP_HTONS(0xffffU - (ICMP_ECHO << 8))) {
iecho->chksum += PP_HTONS(ICMP_ECHO << 8) + 1;
} else {
iecho->chksum += PP_HTONS(ICMP_ECHO << 8);
modify it like below
} else {
iecho->chksum = 0;
For more information regarding this issue, googling with keyword "CHECKSUM_GEN_ICMP".
