10 years, 9 months ago.
Arch Max - Network works fine except ping
The Arch Max and the Arch Pro both have the same Ethernet Transceiver chip, the DP83848J. They use the same EthernetInterface library. I have noticed the Arch Pro can be pinged on it's IP address, and the Arch Max can not be pinged on it's IP address. Otherwise the network works fine with TCP/IP Server/Client, just ping does not work. What can be the reason?
