10 years, 9 months ago.
KL25Z stop working
Please, why after some time 1 hour KL25Z stop working red light only after sift everything is fine if this is just me I took last Pinscape_Controller
regards
Hi - sorry it's not working for you. Without more information, I'm afraid I don't have any guess about what might be wrong. Do you have a plunger sensor attached? What kind of PC are you using, version of Windows, etc? Did you try resetting the KL25Z?
excuse thanks to the rapid response. Windows 7 Enterprise quad intel p5pql-pro. Every day I have to reset 6-7 times. Any information is worth.... I use it just to push, tilt nudge. Future pinball soft. regards
posted by sasa salic 26 Jun 2015
What's the exact behavior when it stops working? You said you get a red light - do you see solid red, one short red flash every few seconds, or two short red flashes every few seconds? I'm guessing it's two short red flashes, which means that the USB connection was lost. If that's the case, you might try putting a USB 2.1 hub between the PC and the KL25Z. I'm suspicious that the KL25Z mbed USB stack might have still some compatibility problems with some USB 3.0 hosts, so a USB 2.1 hub *might* be the solution if you're getting mysterious USB disconnects.
posted by Mike R 26 Jun 2015
two short red flashes every few seconds. I tried the hub 2.0, means that use 2.1 ok I'll try more tomorrow regards
