10 years, 9 months ago.
converting mbed library build into library source?
I remember that I could convert built mbed library (build) into source of library (library) by "Convert to Library" in the right-click menu. In current on-line compiler, I can't find "Convert to Library" there; is this deleted? (I can import "mbed-src" library instead of "mbed" library to get the source.)
Hi Junichi,
I also checked for this and the option is not there anymore. But as you mentioned - you can delete mbed library from your project and import mbed source using "Import library->From import wizard" and choose "mbed-src".
Regards, Miloje
