10 years, 9 months ago.
6DOF stops after awhile
I'm running the the Seeed_Tiny_BLE_Get_Started example, and everything seems fine. But after a few minutes, it does not detect tap motion or orientation changes anymore. LED still blinks slowly (normal), and button press is detected.
I tried reducing the sampling rate of the mpu e.g., /* Starting sampling rate. */
  1. define DEFAULT_MPU_HZ (100)
Seems to help. :)
posted by Cougar GTR 08 Sep 2015
10 years, 6 months ago.
I do experience the same issue too.
I am using the mbed serial port to capture the log data.
I got it to work much better if I uncommented this line above the while(true) loop:
dmp_set_interrupt_mode(DMP_INT_GESTURE);
Not sure why it is commented out before.
posted by Howard Tsoi 08 Sep 2015
