10 years, 9 months ago.
Problem with UDPSocket and ticker.attach
Hi, i've a problem with UDPSocket class when I try to send a message inside a ticker.attach. In fact the board enters a sort of loop and does nothing; and so not send the message. Has someone a solution to this problem?
This is the code:
#include <stdio.h>
#include <string>
EthernetInterface eth;
UDPSocket sock;
Endpoint echo_server_pc;
void UdpSend(){
    //Read EthDevice
    char out_buffer[] = "Hello";
    sock.sendTo(echo_server_pc, out_buffer, sizeof(out_buffer));
int main (void)
    eth.init("192.168.1.101","255.255.255.0","192.168.1.1"); //Not Use DHCP
    eth.connect();
    sock.init();
    sock.set_blocking(false);
    echo_server_pc.set_address("192.168.1.10", 8080);
    //Start the ticker
    tick.attach_us(&UdpSend, 100*1000);//100ms
    while(1){
I've a K64F board. Thanks
