10 years, 9 months ago.
TIM4_IRQHandler() Nucleo F103RB
I've already developped a properly working TIM4_IRQHadnler() on my Nucleo via Eclipse. I try now to use it in mbed, but it does not work. In fact, the TIM4_IRQHandler() function never starts)
I think it is a problem with the startup file and the TIM4_IRQHandler() name. (BTW, I've never find startup file, and I am not include mbed .h in my program since the other functionnalities work properly including "StdPeriphExamples" files)
Has anyone ever faced this problem ? Do you know how to solve it ? Here is its code:
TIM4_IRQHandler()
#ifdef __cplusplus
extern "C" {
#endif
void TIM4_IRQHandler(void)
//Measuring RPM frequency
if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
static uint16_t ICValue1 = 0, ICValue2 = 0;
TIM_ClearITPendingBit(TIM4, TIM_IT_CC3);
if (pulse == 0)
ICValue1 = TIM_GetCapture3(TIM4);
pulse = 1;
else
ICValue2 = TIM_GetCapture3(TIM4);
TIM4CH3Measurement = ICValue2 - ICValue1;
ICValue1 = ICValue2;
#ifdef __cplusplus
#endif
Best regards,
Julien.
I've finally managed to make it work ! I've found the "InterruptManager.h" file, and saw a method with a very beautiful name:
pFunctionPointer_t add_handler_front(void (*function)(void), IRQn_Type irq)
Then I used it in my program like this:
InterruptManager::get()->add_handler(TIM4_IRQHandler, TIM4_IRQn);
And then the interrupt is starting properly. Hope this will help !
Julien.
Assigned to 10 years, 9 months ago.
