10 years, 10 months ago.
Problems compiling mbed - FunctionPointer
It appears mbed (revision 564:24a7119bd73a) won't compile under GCC ARM Embedded.
mbed-src/common/FunctionPointer.cpp:20:1: error: specializing member 'mbed::FunctionPointerArg1<void,void>::FunctionPointer' requires 'template<>' syntax
FunctionPointer::FunctionPointer(void (*function)(void)): _function(),
mbed-src/common/FunctionPointer.cpp:26:6: error: specializing member 'mbed::FunctionPointerArg1<void, void>::attach' requires 'template<>' syntax
void FunctionPointer::attach(void (*function)(void)) {
mbed-src/common/FunctionPointer.cpp:31:6: error: specializing member 'mbed::FunctionPointerArg1<void, void>::call' requires 'template<>' syntax
void FunctionPointer::call(void) {
mbed-src/common/FunctionPointer.cpp:45:1: error: expected '}' at end of input
} // namespace mbed
Any assistance, please?
Thank you
Turns out I updated mbed without removing the old version, and the update has been slightly restructured. FunctionPointer.cpp for example no longer exists
