10 years, 10 months ago.
PWM out for different location
I have currently created a target for the Gecko G800 STK and based it on one of the other targets to create the port. I am using the gecko startup/linker script source files from the Silabs peripheral libraries and have manage to get the LED and serial port working but I am having issue with the PWM output.
I am trying to set PD1 on the eval board but this is located in location 3. From reading the pwmout_api.c, it seems to be set to location 1 by default but there doesn't seem to be an api to set the location. Would this feature be added in the near future or I have I miss something out?
My code for setting up the pwm is shown below. I imagine by setting it, it will use the default period of 20ms.
pwmout for gecko board
PwmOut myPWM(PD1);
int main(void)
while (1) {
My linker script change for the gecko board is shown below and copied all the efm32g source and header from the peripheral libs to the cmsis target folder. I have copied the cmsis files from STK3700 and made the change to the number of vectors; #define NVIC_NUM_VECTORS (16 + 30) . Is there anything that I may have missed out?
linked script change
/* MBED: mbed needs to be able to dynamically set the interrupt vector table. * We make room for the table at the very beginning of RAM, i.e. at * 0x20000000. We need (16+30) * sizeof(uint32_t) = 184 bytes for EFM32G */ __vector_size = 0xBC; ... ... __data_start__ = .; *("dma") PROVIDE( __start_vector_table__ = .); . += __vector_size; PROVIDE( __end_vector_table__ = .); *(vtable) *(.data*) . = ALIGN (4); *(.ram)I fork the mbed repo and added the new target. https://github.com/ubergeekNZ/mbed
posted by Paul Lee 15 Jun 2015Ok figure out where it is set.
