10 years, 10 months ago.
WIZwiki-W7500 Platform
I noticed that the Wiznet WIZwiki-W7500 is listed in the platforms. However, it doesn't appear to be supported yet since I can not add it to my platform list. Do you know when this board will be supported in the compiler? Thanks in advance!
Hi, Doug.
I has the same experience. Now, I success the registeration WIZwiki_W7500 to mbed compiler.
First, You should enable [beta] on https://developer.mbed.org/betamode/ Second, Import mbed_binkly example in the right-side page of WIZwiki_W7500 platform page.
Thank you and enjoy itl.
Thanks for your reply. However, I am still unable to add the board to the compiler even in beta mode. There should be blue button on the platform page for the Wiznet board that says "Add to the mbed compiler". That button is not there. All that is there is a pre-order button.
EDIT: Took another look at it and did the steps you suggested. Sure enough...it imported the WizNet board into the compiler. My apologies for not trying it in the first place.
EDIT #2: Looks like the board is not fully supported in the compiler yet. Please see this post:
https://developer.mbed.org/questions/54049/hardware-is-not-recognized-compile-error/
posted by Doug . 15 Jun 2015
Hi, Doug! You should update mbed library in the web-compiler.
In the web-compiler, Double-click "mbed" library in the left window, and you can show mbed icon to be changed to green color. And then, Click "Update" button in the right window.
Thank you.
posted by Midnight Cow 18 Jun 2015
