10 years, 9 months ago.
K64F USB Host SOF Issue
I'm using a modified version of the F401RE-USBHost (modified by me to get it to work with the K64F).
I'm having a problem when I'm communicating with a USB display when I'm in USBHost mode with my K64F. The problem is that every 10 seconds or so I'll see a pause or hiccup in processing.
I hooked up a USB Analyzer and found out I'm getting SOF errors occasionally, I believe it's showing me the missing frame id, like:
(GOOD) [5 SOF] [Frames: 338-342]
(BAD)  [1 SOF] [Frame: 344]
(GOOD) [8 SOF] [Frames: 345-352]
Even when there's no data being sent back-n-forth it looks like this...
(GOOD) [2000 SOF] [Frames: 770-721] [Periodic Timeout]
(GOOD) [1200 IN-NAK] [Periodic Timeout]
(GOOD) [1988 SOF] [Frames: 722-661]
(BAD)  [1 SOF] [Frame: 663]
(GOOD) [8 SOF] [Frames: 664-671]
So, I think it must be some timing issue maybe? Anyone have any clues what I can look for or look at? I'm really lost, but I need to figure this out.
Kind Regards, Jeff
