10 years, 10 months ago.
Error: Class "GPIO_TypeDef" has no member "BSRRH"
Good day,
Thank you for making the code available on mbed. I am trying to use it with my F411RE board, but I get the following errors:
Error: Class "GPIO_TypeDef" has no member "BSRRH" in "TFT_ILI9163C/TFT_ILI9163C_F411RE_DMA_IT.cpp", Line: 191, Col: 18 Error: Class "GPIO_TypeDef" has no member "BSRRL" in "TFT_ILI9163C/TFT_ILI9163C_F411RE_DMA_IT.cpp", Line: 195, Col: 18 Error: Class "GPIO_TypeDef" has no member "BSRRH" in "TFT_ILI9163C/TFT_ILI9163C_F411RE_DMA_IT.cpp", Line: 199, Col: 18 Error: Class "GPIO_TypeDef" has no member "BSRRL" in "TFT_ILI9163C/TFT_ILI9163C_F411RE_DMA_IT.cpp", Line: 203, Col: 18
What am I doing wrong?
Thank you
He uses direct register access to speed up the code. However in recent mbed version some register names for your device were changed. You can go back to an older revision of the mbed library and it should work again.
A "quick fix" would be to change TFT_ILI9163C.h to:
#if defined(TARGET_NUCLEO_F411RE) // #define __F411RE_SOFT__ // #define __F411RE_DMA__ // #define __F411RE_DMA_IT__ #define __MBED_GENERIC__
It now compiles and runs, although the performance is slower. Not a perfect or ideal fix, but at least I can test the displays.
posted by 28 May 2015
