11 years, 4 months ago.
CellularModem Port compile errors
Hi
I'm trying to port the UbloxModem and CellularModem libraries to work with a Nimbelink Skywire modem. I'm using Nimbelink's arduino shield sitting on top of a STM32F401RE Nucleo board. When I try to compile inside the online compile I get several errors pointing to a stm32f401xe.h file.
Error: Expected an identifier in "extras/mbed_031413cf7a89/TARGET_NUCLEO_F401RE/stm32f401xe.h", Line: 213, Col: 17 Here are a couple lines of code that it errors on...
__IO uint32_t CR;            /*!< PWR power control register,        Address offset: 0x00 */
__IO uint32_t CR;            /*!< RCC clock control register,          Address offset: 0x00 */
__IO uint32_t CR;            /*!< RTC control register,                    Address offset: 0x08 */
I have already compiled a very simple program that just does serial pass thru to the modem so I know that works. Any ideas, I'm still very new to mbed.
Thanks Kevin
So if I target the C027 board everything compiles and I get a binary out. I had to change the hardware Pin names but that's all I change to get it to work on the C027. Any thoughts??? Does the Nucleo mbed library not support something?
posted by Kevin Holland 20 Nov 2014
After digging a bit the fwk.h file in the CellularModem lib has a define for CR. This interferes with all target platforms that use CR in their register typedef, Specifically I tried ST and Freescale
posted by Kevin Holland 21 Nov 2014
