13 years, 3 months ago.
Difficulty in writing to mbed
I just bought my NXP LPC1768,once I tried to download any program in to my mbed it just hanged and I need to disconnect it and reconnect again. It happens frequently.
I just write my hello program(very basic)and click compile
Can any one advice?
Also I have these files after my mbed hanged
Hi Majed,
Have you tried to format the Mbed disk (right click on MBED(H:) then format) ? After having formatted the disk, try to drag and drop your hello world program.
Cheers, Sam
Hi
thanks for your responding. I tried twice it just freeze and after I switch it off it cleaned every things but same problem when I try to download it goes ok for first time but after that same things
Could you check downloading using a different browser or computer ? So as to see if it is an mbed problem or environment problem ?
Do you get " new " files inside mbed flashdisk , after format ? ( except the .....1768.bin file ? ) The two last files you mention are two big to be compiler generated ... It seems to me that something is trying to access your mbed flash disk ( a virus or a torrent program ) and stores too much data , causing mbed to hang.
Cheers , Christos
Hi
I download the files to my folder first then I moves it to mbed but same thing. know it accepts the quick format and only the original file is their.
The only way I found is to disconnect the mbed every time before I put new file.
