11 years, 4 months ago.
Example usage of AdaFruit_RGBLCDShield:AdaFruit_RGBLCDShield?
Do you have an example that uses this library. I'm trying to use it with a LPC1768 and am having some problems with it.
I had to change two lines like
Serial(SERIAL_TX, SERIAL_RX) to Serial(USBTX, USBRX) to get the Adafruit_RGBLCDShield.cpp to compile.
I copied the Hello World example from adafruit and am getting other compile errors starting with
Error: No instance of constructor "Adafruit_RGBLCDShield::Adafruit_RGBLCDShield" matches the argument list in "main.cpp", Line: 10, Col: 29
Thanks
Eric
