11 years, 4 months ago.
RTOS on FRDM-K20D50M?
Hi, is the RTOS supporting FRDM-K20D50M board with a MK20DX128 Cortex-M4
I've tried imporitng it - got a bunch of compile errors, worked through some of them but then hitting Error: A1854E: Unknown opcode 'VSTMDBEQ', maybe wrong target CPU? in "mbed-rtos/rtx/TARGET_CORTEX_M/TARGET_M4/TOOLCHAIN_ARM/HAL_CM4.c", Line: 157, Col: 2 Which is hitting the limits of my knowledge?
thanks Neil
That was an issue recently noticed, see: https://github.com/mbedmicro/mbed/issues/612.
Hello Erick, many thanks for the link, and also found this. https://developer.mbed.org/questions/5045/mbed-RTOS-support-on-K20D50M/ So interesting - an ARM based cortex-M4 processor from Freescale has compiler errors on ARMs mbed.org - the question was posed 18days ago and not been solved. The MK20 is a core processor as part of the Freescale CMIS-DAP implementation.
Martin, I wonder is there a timeline from ARM that is more definitive, ? Do you think I should be using Kinetis Design Studio for my project? many thanks
posted by 14 Nov 2014ARM's RTOS supports it, the mbed build system doesn't use the correct RTOS files (which is partially due to how ARM names them, and yeah mbed = ARM, but still different of course in practise).
I would have made a (partial) solution, but that user indicated he would look further into it. So thats why I at least didn't look further into it.
posted by 14 Nov 2014Erik appreciate the information. Practically speaking - using mbed.org I'm dead in the water right now. I appreciate mbed.org as communications hub as well as the tools support, but its not clear with this critical error if anybody dependable has signed up to clear it up. (I don't have the insights) I tried to build by pulling just the source from github.com and build just core "mbed" directory in KDS 1.1.1 - and it needs <rt_misc.h> - and I can't find it anywhere - except for some references to it on arm.com. Any ideas or should I ask a separate question. Practically speaking with FRDM-K20D50 as a starting point - see some other comments I've made - I'm dead in the water with mbed.org - I like mbed architecture and what its talking about - but if I can't put a tools environment together .......
posted by 17 Nov 2014I don't use KDS myself, so wouldn't know how to do that. I have a basic github environment which I just use to command line compile, and if I want it in an offline environment I generally export from the mbed compiler. Is there a KDS export available?
Regarding your RTOS issue: The easiest solution to get it working online should be copying the HAL_CM3.c contents into HAL_CM4.c. (They are in RTX/Cortex-M/Target_M3/4/Toolchain_ARM)
