10 years, 9 months ago.
Nrf51822 app_uart_init issue
Hey there,
Hopefully this issue is pretty straightforward, but I suspect it may be something more devilish. I am trying to set up an Nrf51822 as a radio go-between with another MCU and a phone. I am starting with the BLE_LoopbackUART project and can successfully connect to a smartphone. I am using this module - https://developer.mbed.org/platforms/Nordic-nRF51-Dongle/
Now I am trying to set up the hardware uart so that I can start moving the data through to the other MCU, but I'm getting the following error when calling app_uart_init :
undefined symbol app_uart_init ( const app_uart_comm_params_t*, app_uart_buffers_t*, void(*)(app_uart_evt_t*), app_irq_priority_t, unsigned short*)
relevant code chunk
#include "app_uart.h"
void uart_evt_handler( app_uart_evt_t * p_app_uart_event){
void init_uart_module(){
//configure our UART module settings
app_uart_comm_params_t uart_module;
uart_module.rx_pin_no = 20;
uart_module.tx_pin_no = 19;
uart_module.rts_pin_no = 18;
uart_module.cts_pin_no = 17;
uart_module.flow_control = (app_uart_flow_control_t)APP_UART_FLOW_CONTROL_LOW_POWER;
uart_module.use_parity = false;
uart_module.baud_rate = 1000000;
uint32_t err_code_;
app_irq_priority_t priority_ = APP_IRQ_PRIORITY_HIGH;
// APP_UART_FIFO_INIT( &uart_module, 100, 100, uart_evt_handler , priority_, err_code_) ; //Have an issue using this Macro, or calling the function directly
uint16_t uart_id = 0;
app_uart_init(&uart_module, NULL, uart_evt_handler , priority_, &uart_id);
From what I can tell from the error, there are 2 problems :
1 - The compiler thinks the third input paramater is of the wrong type - void(*)(app_uart_evt_t*) but I have tried casting uart_evt_handler, and I am using the same formatting and code as is used in the nordic example code
2 - It thinks that the last input parameter is of type unsigned short*, though it should be of type uint16_t *. Again explicit casting doesn't fix this.
Any thoughts on what is going on here?
Thanks, Steve
Where should app_uart_init be defined?
posted by Martin Kojtal 26 May 2015in app_uart.h , which is included, and which is also where the app_uart_comm_params_t struct is defined, as well as some other things in use, and that has no issues.
posted by Stephen Hibbs 26 May 2015Hi Steve,
I am having the same problem. If you have solved this issue, please help me for the same.
Thanks, Akshat
posted by Kishore Chilakala 05 Aug 2015Nope, after much wasted time i just moved to using the Serial library, which works ok.
posted by Stephen Hibbs 05 Aug 2015thanks for your response, I am doing the same thing
posted by Kishore Chilakala 06 Aug 2015
