10 years, 10 months ago.
SD Card on FRDM KL25Z
How use SD Card on FRDM KL25Z
10 years, 5 months ago.
Does this library has read methods too?
Yes, you can read from files on the SD card using standard functions. Example:
Reading from a file on the SD card
     printf("Reading from SD card...");
     fp = fopen("/sd/mydir/test.txt", "r");
     if (fp != NULL) {
         char c = fgetc(fp);
         if (c == 'H')
             printf("success!\n");
         else
             printf("incorrect char (%c)!\n", c);
         fclose(fp);
     } else {
         printf("failed!\n");
posted by Frank Agius 12 Oct 2015
10 years, 8 months ago.
First you attach an SD breakout board, such as this one from sparkfun: https://www.sparkfun.com/products/544 Or if you have a spare SD card adapter and are handy with a soldering iron, you can make your own: http://www.bot-thoughts.com/2010/02/logging-data-to-sd-cards.html
Here's the code that should be able to write to a FAT formatted SD card. I used the SD FileSystem library from here: https://developer.mbed.org/users/neilt6/code/SDFileSystem/
kl25z example interfacing to an SD card. Include the SDFileSystem library with this code
include "mbed.h"
#include "SDFileSystem.h"
 // sd card breakout board: https://www.sparkfun.com/products/544
 // frdm-kl25z sd card connections spi0
 // Header -- kl25z -- SPI
 // J2-8   -- PTD2  -- MOSI
 // J2-6   -- PTD0  -- CS
 // J9-12  -- GND   -- Vss (GND)
 // J9-4   -- P3V3  -- Vdd (+3.3v)
 // J2-12  -- PTD1  -- SCK
 // J9-14  -- GND   -- Vss (GND)
 // J2-10  -- PTD3  -- MISO
SDFileSystem sd(PTD2, PTD3, PTD1, PTD0, "sd"); //  mosi, miso, sck, cs
Serial pc(USBTX,USBRX);
    printf("start sd card test!\r\n");
    mkdir("/sd/mydir", 0777);
    FILE *fp = fopen("/sd/mydir/test.txt", "w");
    if(fp == NULL) {
        error("Could not open file for write\r\n");
    else
        printf("file opened for writing\r\n");
    fprintf(fp, "Hello fun SD Card World!");
    fclose(fp);
    printf("completed sd card test!\r\n");
