10 years, 10 months ago.
error: #397 in Timer.h when trying to compile
after spending some time in setting up my environment I'm in the phase of complilation.
Meanwhile I updated all libraries used in this example but I still end up with one error I'm not able to analyze/understand: Error message is: # mbed\Timer.h(45): error: #397: implicitly generated assignment operator cannot copy: const member "mbed::Timer::_ticker_data" class Timer { ^ detected during implicit generation of "mbed::Timer &mbed::Timer::operator=(const mbed::Timer &)" at line 11 of "MQTT\MQTTmbed.h" #
The problem persists independently whether I use ARM mbed online compiler or uVision V5 locally.
Any ideas how to get rid of this ?
Kind regards uef
Thanks for the report. I think this is a problem with mbed library (from rev 98 onward).
I have raised an issue here: https://github.com/mbedmicro/mbed/issues/1124
To workaround this, please change mbed library revision 97 (or older). Right click "mbed" library in your project - Choose "Revisions..." - Click Rev "97" - Click "Switch" button.
Thanks for reporting and @MACRUM for adding this to github. This is PR for this issue: https://github.com/mbedmicro/mbed/pull/1125
This will be fixed in next revision of the mbed library.
