10 years, 9 months ago.
how do i make lm75b as the interruptin to be event triggered?
osMode();
    /** Set the OS pin mode of the LM75B
     * @param mode The new OS pin mode as an OSMode enum.
i am working on a project that i think i have to use event triggered interrupt, when my mic voltage is above threshold, interruptin will rise so it will be a HIGH and vice versa. i am having problem making the lm75b temperature as a interrupt. i know that i have to use osmode to configure it and stating its default address.do i have to solder a wire to from the os which is pin 3 to somewhere?can someone share with me to how to configure it as an interrupt.thank you
#include "mbed"
 #include "LM75B.h"
AnalogIn  rightmic(p16);
InterruptIn sensor(p28, p27);//supposely this should be LM75B
Timer t;
void right()
t.start();
float sample=rightmic.read()*3.3;
printf("%f",sample);
t.stop();
printf("%f", t.read());
t.reset();
while(1)
sensor.rise(&right);//if it is a HIGH it will run the function of right.
this so far what i have tried.
posted by faris abdat 20 May 2015
