10 years, 10 months ago.
ADC Read Problem
I connected the ADC pin 0 to the output of the light sensor and ran the following code. But the ADC values dont respond to the voltage on the LIGHT_SENSE output or any other analog signal. Any clues what the problem might be?
AnalogIn adc0(PD0); // ADC Channel 0
Serial PC(USBTX, USBRX);
DigitalOut LESDrive(PD6); // Light Sensor Excitation
LESDrive.write(1); // Turn on Light Sensor.
while(1)
pc.printf("ADC0=%d\n", adc0.read_u16());
wait(1.0);
Verified with a multimeter that the LIGHT_SENSE signal is changing between 0-3 volts. But I'm getting flat 0 Output:
ADC0=0 ADC0=0 ADC0=0 ADC0=0
I would appreciate any help! Thank you.
Turns out our API's don't properly enable the clocks for the peripheral yet.
I added
analogin_api.c
CMU_ClockEnable(cmuClock_ADC0, true);
to analogin_init(analogin_t *obj, PinName pin) in analogin_api.c and now it at least gives me some output:) Cannot verify if it's the correct output.
By the way, the quickest way to debug these problems is to export the project to Simplicity studio like this. Also it is much easier to debug when using mbed-src instead of mbed.
I finally got the ADC working. The ADC handle was not being initialized so I initialized it as shown in the included code. I'm not sure if that's the most elegant way to do it (since ADC0 is hard coded) but it worked for me.
void analogin_init(analogin_t *obj, PinName pin)
// Initialize ADC handle to ADC base address
obj->adc = ADC0;
/* Init with default settings */
ADC_Init_TypeDef init = ADC_INIT_DEFAULT;
ADC_Init(obj->adc, &init);
ADC_InitSingle_TypeDef singleInit = ADC_INITSINGLE_DEFAULT;
/* Init for single conversion use, measure input channel with Vdd reference. */
singleInit.reference = adcRefVDD;
singleInit.resolution = adcRes12Bit;
singleInit.acqTime = adcAcqTime32;
singleInit.input = adcSingleInpCh0;
ADC_InitSingle(obj->adc, &singleInit);
/* Init pins */
analogin_preinit(obj, pin);
