10 years, 11 months ago.
KL25Z drivers on Windows 7
The KL25Z opens the mbed drive on Linux without problems but on Windows it only shows a unrecognized device called "USB_MSC" and I have no drivers for it, does anyone knows where can I get the drivers ?
Have you installed the mbed firmware? https://developer.mbed.org/handbook/Firmware-FRDM-KL25Z Also, I guess you would need the Windows Serial port driver as well: https://developer.mbed.org/handbook/Windows-serial-configuration
I already made that and the issue remains. Actually, it is working on Linux, only in Windows that this problem is happening. Very annoying.
posted by Christian Perone 20 May 2015
Are the Linux and the windows machines the same box? Have you tried in a different USB port/hub?
posted by Sebastián Pastor 20 May 2015
Yes, Linux and Windows are in the same box, the Linux is inside a VM on the Windows, this is very weird. I have antoher mbed device and it recognizes the MBED drive as "USB_MSC" too, however it doesn't find any driver for it. I'll try another USB port to check if this could be solved.
posted by Christian Perone 23 May 2015
