10 years, 11 months ago.
minimum resolution of ticker
hello everybody,
i have a question about ticker period. can i use ticker period below 1 us?
thank you
Hi Edwar,
The mbed API only officially supports microsecond resolution. Certain platforms may have a higher resolution available, but you would have to write to the appropriate registers yourself. Which platform are you using?
Thanks,
Brian
hi brian,
thank you for your reply
I am using mbed LPC1768. which platform does has higher resolution? do you have the reference to write the register manually so i could achieve higher resolution ticker?
Edwar
posted by 18 May 2015You have to change the counter prescalar manually, though note that it will affect wait(), wait_ms() and wait_us(). The implementation of the ticker interrupt is in us_ticker.c. Btw some platforms use worse than 1us resolution, e.g. nRF51822 which uses a 32kHz ticker instead of 1 MHz.
posted by 28 May 2015
