11 years, 5 months ago.
What is interfering with my motor class?
Using the FRDM-MKL25Z
Almost everything is working except for motor2(PTA4).
I feel like it could be some sort of interfering issue with the timers, by that I mean two different instances are using the same timer but have different configurations. I've tried having the classes that uses a timer initialized in different order but doesn't seems to work.
I've tried switching the 4 pins around but it seem persistent with PTA4. Physically these pins now are is more accessible, so I haven't tried switching to a different set of pins yet.
The overall program is pretty large so you check out at the link below, but I've also included the code of the header file.
What is possibly going wrong? What else can I try?
http://developer.mbed.org/users/oprospero/code/quadCommand7v2/
/************************* quadCommand.h *********************************/
#ifndef QUAD_COMMAND_H
#define QUAD_COMMAND_H
#include "motor.h"
#include "com.h"
#include "Sensor.h"
#include "PID.h"
#include "KL25Z_Watchdog.h"
#include "RGBled.h"
#define DOGTIMER 0.5f
// Motor constants.
#define MOTOR1              PTA5    // PTA5    // Pin used for motor 1.
#define MOTOR2              PTA4   // PTA4    // Pin used for motor 2.
#define MOTOR3              PTA12    // PTA12   // Pin used for motor 3.
#define MOTOR4              PTD4    // PTD4    // Pin used for motor 4.
// Xbee constants.
#define TXPIN               PTA2        // Pin used for xbee TX.
#define RXPIN               PTA1        // Pin used for xbee RX.
#define RSSIPIN             PTD5        // Pin used for xbee RSSI
// Sensor constants.
#define MMA8451_I2C_ADDRESS (0x1d<<1)   // Address of I2C accelerometer.
#define ACCSDA              PTE25       // Pin for accelerometer SDA line.
#define ACCSCL              PTE24       // Pin for accelerometer SCL line.
#define ROLLTHROTTLEGAIN    0
#define PITCHTHROTTLEGAIN   0
#define YAWTHROTTLEGAIN     4
// PID constants.
// D = 450 shaking
//High throttle(<200) 0.6     0   450
//Low throttle(<100)  0.45    0.1 80
#define PID_P_PITCH 1.1                     // Proportional gain.
#define PID_I_PITCH 0.0                       // Integral gain.
#define PID_D_PITCH 140.0                       // Derivative gain.
#define PID_P_ROLL 1.1                       // Proportional gain.
#define PID_I_ROLL 0.0                     // Integral gain.
#define PID_D_ROLL 140.0                       // Derivative gain.
#define PID_P_YAW 2.2                    // Proportional gain.
#define PID_I_YAW 0.0                       // Integral gain.
#define PID_D_YAW 40.0                       // Derivative gain.
#define TRIM_VALUE 0.5f
#define THROTTLE_THRES 16
#define PITCH_RANGE 10
#define PITCH_MULTI 4
#define PITCH_LOW_RANGE -PITCH_RANGE*PITCH_MULTI+64
#define PITCH_HI_RANGE PITCH_RANGE*PITCH_MULTI+64
#define YAW_RANGE 60
#define YAW_MULTI 1
#define YAW_LOW_RANGE -YAW_RANGE*YAW_MULTI+64
#define YAW_HI_RANGE YAW_RANGE*YAW_MULTI+64
#define MAX_CORRECTION_VALUE 10.0       // Integral windup.
#define DEFAULT_WINDUP_GUARD 10         //MAX_CORRECTION_VALUE / PID_I_PITCH       // Integral windup.
#define YAW_WINDUP_GUARD 50
#define MOTOR_UPDATE    10             // Motor update speed.
#define TIMEOUT_TIMER   2.0
#define THROTTLEPERSEC  500.0
#define THROTTLEJUMP THROTTLEPERSEC / 1000.0 * MOTOR_UPDATE
#define TIMEOUT  TIMEOUT_TIMER / MOTOR_UPDATE * 1000
#define ROLLYAWJUMP 2.0
#define YAWCUTOFF 10
class quadCommand
    public:
    quadCommand();  // Constructor
    void run();     // Main loop
    private:
    void rxInput();     // Receive data from Xbee
    void updateMotors();    // Send PID values to Motors
    void readyMotors();     // Callback function for update
    com *myCom; // Serial
    Sensor *mpu; // I2C
    motor *myMotor1; // 1 PWM
    motor *myMotor2; // 1 PWM
    motor *myMotor3; // 1 PWM
    motor *myMotor4; // 1 PWM
    PID pidPitch;
    PID pidRoll;
    PID pidYaw;
    RGBled led; // 3 PWM
    Timer time;
    Watchdog dog; // Timer
    Ticker motorProcess;
    volatile bool need2update;
    //Control Variables
    float targetThrottle,   previousThrottle,   throttleHelper,     throttle;
    float targetPitch,      followPitch,        currentPitch,       pitch;
    float targetRoll,       followRoll,         currentRoll,        roll;
//    float targetYaw,        followYaw,        currentYaw,         yaw;
    float targetGyroYaw,    followGyroYaw,    currentGyroYaw,     gyroYaw;
    float pitchTrim, rollTrim , gyroYawTrim;
    unsigned int rxTimeout;
    unsigned int dt;
#endif
It uses the same PWM unit as one of the RGB led ones. Here is list of PWM units and their pins: http://developer.mbed.org/users/mbed_official/code/mbed-src/file/be043393235b/targets/hal/TARGET_Freescale/TARGET_KLXX/TARGET_KL25Z/PeripheralPins.c
The RGB led is PTB18, PTB19 and PTD1 (that one being the problem).
Thanks for your answer I've fixed it by change the RGB into just and IO pin. However some thing still doesn't make sense to me. The commonality that I see between PTD1 and PTA4 is that they use TPM0 but so do 2 of the other pins that I use. Why does it not affect those?
posted by Prosper Van 02 Nov 2014
They don't just use the same timer, they also use the same match channel of that timer. The others use a different match channel, then you can have different PWM ratios (but they would need to have the same period still).
posted by Erik - 02 Nov 2014
