11 years, 4 months ago.
Non-blocking for received method
Good morning,
Is there a non-blocking solution for the receive method? I'm trying to control a small LED matrix where I have to switch all the rows in a specific moment. If nothing is sent over the network, the matrix will stop displaying.
int main (void) {
pc.baud(9600);
pc.printf("Started\r\n");
EthernetInterface eth;
eth.init(); // Use DHCP
eth.connect();
pc.printf("IP Address %s\r\n", eth.getIPAddress());
TCPSocketServer server;
TCPSocketConnection sock;
server.bind(SERVICE_PORT);
server.listen();
server.set_blocking(false, 500); // SET NON-BLOCKING
pc.printf("Service binded to port %d\r\n", SERVICE_PORT);
while (true) {
pc.printf("Waiting for connection\r\n");
TCPSocketConnection client;
server.accept(client);
//client.set_blocking(false, 500); // Timeout 500ms
pc.printf("Connection from %s\r\n", client.get_address());
char buffer[100];
while (true) {
led1 = true;
int n = client.receive(buffer, sizeof(buffer));
/* Parsing received buffer for my matrix display */
// Returning message to client
client.send_all("*ok;", 4);
if (n <= 0) break;
/* Controlling all the lines of my matrix */
display();
led1 = false;
client.close();
Regards
7 years, 1 month ago.
For those of you still searching for the answer yes, there is a non-blocking mode. The mode .set_blocking is inherited by Socket.h.
server.set_blocking(false, 10); Timeout after (10)ms
Apply this to INSTANCE of TCPSocketServer, TCPSocketConnection, etc.
e.g. sock.set_blocking(false, 10) or client.set_blocking(false, 10);
Hope this helps.
