11 years, 5 months ago.
OO Design methodology
Are object-orientated design principals followed during the design process for the software modules. Using UML to do an OO design is a great advantage for re-use and maintenance.
The mbed C++ is really mainly a shell around the actual C code, so the C++ part is relative straight forward.
If you want you can use for example doxygen to generate documentation, which also includes inheritance diagrams.
Hi, can you be more specific, which principles ? Or what's the aim of this question? To get a proper answer.
posted by Martin Kojtal 29 Oct 2014We use EnterpriseArchitect (supporting UML) to design software for C++ object orientated implementations, eg. Use an abstract base class 'Port' and then sub-classes implement the Port for their specific functionality like 'RadioPort' or 'SerialPort'. EA allow importing of C++ designs and stub-code generation. (I can submit a picture but do not know if it is possible)
posted by Jaco van der Merwe 29 Oct 2014
