11 years, 4 months ago.
Drag & Drop .bin file
I tried to start following the instructions to run the first code. However, it says to drag and drop the .bin file into the mbed Microcontroller drive. The error message I get every time I plug the freedom board in is: "OS X can't repair the disk 'MBED.' You can still open or copy files on the disk, but you can't save changes to files on the disk. Back up disk and reformat it as soon as you can." How can I troubleshoot?
is this relevant to your issue https://github.com/mbedmicro/CMSIS-DAP/issues/69 ? Will be fixed.
0xc0170
