11 years, 5 months ago.
FRDM KL25Z working backwards
Hi, im using an FRDM KL25Z board, with this code:
DigitalOut myled(LED1);
          myled=1;
But instead of turning on the led assigned, is turned off. and when i put the following code
          myled=0;
instead of turning off the led assigned, is turned on.
Is something wrong with my board?
Greetings
That's normal. LEDs are pulled-up.
Hi, thanks for the answer, how i do to make working the right way?
posted by Ney Palma 23 Oct 2014
@Ney, look at schematic how they are connected (pull up there), you can change i t to pull down with some tweaking, but is that what you really want?
posted by Martin Kojtal 23 Oct 2014
