10 years, 10 months ago.
Seeed Arch Max - Function of 36 pin J2 connector?
On the Seeed Arch Max, what's the function of the 36 pin J2 connector?
Well, from the labeling of the pins - it is primarily a 16 bit external memory interface. There is an I2C connection, some bootx pins (not sure) and the control signals for the external memory buss. Not sure what the main processor chip is on this board.
- A lot of it depends on how you map the pins in the GPIO matrix that most of these chips have.
According to the schematic, both pin 1 and pin 36 are 5v.
Here's the schematic: http://www.seeedstudio.com/wiki/images/b/bb/Arch_Max.pdf
Also, looking at the board, it appears the "5v" marking is mean for both of those pins (1 and 36).
