11 years, 5 months ago.
Using Extended can1.read returns 0
I need help as to why this wont work (code below).
When I use CANStandard it works perfectly. Using CANExtended this if statement is false. I do know the message is received and working. Meaning I create a filter and trigger an interrupt only when a specific Extended ID is received. Code functions correctly and my data for the rx ID i'm looking for is updated. When I check can1.read(canMsg) during that same cycle - it always returns false on extended but my variables are being updated with the correct data.
thanks, Rob
CAN read returns false on Extended
CANMessage canMsg;
if (can1.read(canMsg)) {
printf(" ID%08x ", canMsg.id);
10 years, 8 months ago.
I am having exactly the same issue. Is there a fix for it?
EDIT:
I just figured it out.
This code should clarify it:
Extended ID:
while (!can1.write(CANMessage(msgid, reinterpret_cast<char*>(&payload), 8, CANData, CANExtended))){}
Standard ID:
while (!can1.write(CANMessage(msgid, reinterpret_cast<char*>(&payload), 8))){}Standard ID
Thanks!
