11 years, 5 months ago.
question on BufferedSerial::prime function
I have question about the following code. We are calling the BufferedSerial::txIrq() function and also attching to TxIrq. What is the purpose of the last two lines ?
void BufferedSerial::prime(void) { if already busy then the irq will pick this up if(serial_writable(&_serial)) { Serial::attach(NULL, Serial::TxIrq); make sure not to cause contention in the irq BufferedSerial::txIrq(); only write to hardware in one place Serial::attach(this, &BufferedSerial::txIrq, Serial::TxIrq); }
return; }
TxIrq is the single place writes to hardware occur. The TX interrupt is off by default and until there is data in the buffers. To enable the TX interrupt in a semi-generic way (ie some always fire when available and others only once) we make that call and then enable the TxIrq to empty the rest of the buffer.
As per my understanding, the function call to BufferedSerial::txIrq(); transmits the entire software buffer as we have a while loop. After this function call enabling the Txirq to empty the rest of the buffer does not seems correct. What is your opinion ?
I have clearly understood how the RX interrupt works. I am not quite sure how you are using the TX interrupt in your code.
Can you please describe more about it.
posted by 24 Oct 2014
