11 years, 5 months ago.
11u68 Serial printf not working
I am unable to get the Serial class working on the LPC11U68. I updated the firmware and can download and run mbed blinky without a problem. The virtual serial port does not enumerate and I cannot print using the printf command. I can print using the USBDevice driver and the target USB connector. Everything works perfectly with the KL25Z using the same code (just switch platform and recompile). Could I have some sort of PC driver problem?
Thanks, Tom
If this is solved, can you you share the solution? There might be a user with same problem and will find it helpful.
0xc0170
Problem solved.
posted by Tom Russell 21 Oct 2014
