11 years, 5 months ago.
My public app doesn't show up when I search the Import index
http://developer.mbed.org/teams/ACKme/code/ACKme_HelloWorld/ is set to public but it doesn't show up when I use the Import Wizard to search the importable programs for 'ACKme_HelloWorld'. It does show up in the search results if I blank the search term field, sort by modified and scroll through to find it. What's happening here? Is this a bug or am I missing something? Thanks.
I just searched for ACKme_HelloWorld and it shows up in the results on http://developer.mbed.org and in the IDE. Can you try again and let me know if the results are still not present?
Thanks Sam. I recreated the repository in http://developer.mbed.org/teams/ACKme/code/ACKme_HelloWorld/ and it was eventually indexed properly. The problem is apparently something to do with forking from the original repository. It's not forked any more.
posted by 22 Oct 2014Assigned to 11 years, 5 months ago.
I originally created this elsewhere, with Public (unlisted) visibility, then moved it to http://developer.mbed.org/teams/ACKme/code/ACKme_HelloWorld/
posted by Neale Morison 20 Oct 2014
