11 years, 6 months ago.
Connecting nRF24L01 to FRDM-KL46Z48M Board
I am working on a project where I would like to use nRF24L01 with FRDM-KL46Z48M board.. However I am a bit confused about which mbed pins to connect to the nRF24L01 pins ?
What should be the proper update for the pins in this line in order to get the code working as the freedom board does not have p5, p6, p7, p8, p9, p10 pins ?
nRF24L01P my_nrf24l01p(p5, p6, p7, p8, p9, p10); mosi, miso, sck, csn, ce, irq
Thanks in advance, Moustafa
11 years, 5 months ago.
Hi Moustafa,
From your profile, it looks like you're using the KL46Z dev board. The nRF24L01 uses the SPI interface. The p5, p6, p7, p8, p9, p10 pin names are a reference to the pinouts of an LPC1768 platform, which I'm assuming was used by the developer of this library. From the pinout diagram, there are two SPI busses you can use on your board:
SPI0 : PTA15-PTA17
SPI1 : PTD5-PTD7
It looks like the Green LED on your board uses PTD5, so probably better to use SPI0. I believe the CSN, CE and IRQ can be any digital pins.
Your code would look like the following (with csn, ce and irq replaced with the pin you've physically connected them to):
//Example declaration using SPI0 on PTA nRF24L01P my_nrf24l01p(PTA16, PTA17, PTA15, CSN_PIN, CE_PIN, IRQ_PIN); //mosi, miso, sck, csn, ce, irq
https://developer.mbed.org/platforms/FRDM-KL46Z/
Harsh
